[petsc-dev] getting rid of clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
Jed Brown jed at jedbrown.org
Thu Apr 3 17:28:22 CDT 2014
Barry Smith <barryfsmith at me.com> writes:
>   Jed,
>    Could gmakefile be modified with
> PETSC_COMPILE.cxx = $(call quiet,CXX) -c $(CXX_FLAGS) $(CFLAGS) $(CCPPFLAGS) $(CXX_DEPFLAGS) $(CXX_X_FLAG)
> and
> CXX_X_FLAG set to -x c++
> by configure when it works to get rid of that damn clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
> message?
It could, but the problem is that if this option is ever passed (perhaps
accidentally) when you run the compiler on something that is not C++
source, the compiler will SEGV (this bug is now fixed) or do something
nonsensical.  For example
  clang++ -x c++ foo.o -o foo
It should be able to go in CCPPFLAGS, provided it is never used incorrectly.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140403/973f00f0/attachment.sig>
