[petsc-dev] METIS update -> MUMPS crash
Garth N. Wells gnw20 at cam.ac.uk
Sun Sep 1 09:37:29 CDT 2013
I've been having trouble with MUMPS crashing since METIS was recently updated in
    https://bitbucket.org/petsc/petsc/commits/67125ba
The problem does not appear for very small problems, but for other
problems it does. I can reproduce a crash with ex55
(src/ksp/ksp/examples/tutorials/ex55.c):
    ./ex55 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package
mumps -ksp_view -ne 128
For 'ne' less than about 50 it runs fine but crashes for anything
bigger. Changing the LU solver to another package it runs fine.
Backtrace below. The message
    http://www.mail-archive.com/petsc-users@mcs.anl.gov/msg17695.html
looks to be related.
Garth
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x80a46)[0x7f877c6f4a46]
/home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(gk_gkmcorePop+0x81)[0x7f877be7fcae]
/home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(gk_malloc_cleanup+0x3f)[0x7f877be6c418]
/home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(METIS_NodeND+0x6de)[0x7f877be9fa02]
/home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(metis_nodend_+0x48)[0x7f877be94ba8]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_195_+0x3720)[0x7f877e67ac40]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_26_+0x279c)[0x7f877e553d30]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_+0x2022)[0x7f877e638756]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_f77_+0x16eb)[0x7f877e51a567]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_c+0x12a5)[0x7f877e4f2fed]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(MatLUFactorSymbolic_AIJMUMPS+0xa88)[0x7f877dc00d11]
/home/garth/local/gcc/petsc-test/lib/libpetsc.so(MatLUFactorSymbolic+0xb61)[0x7f877db6a82f]
/home/garth/local/gcc/petsc-test/lib/libpetsc.soAborted (core dumped)
