[petsc-dev] how to rebase together last two commits in branch?
Tue Oct 22 14:14:47 CDT 2013
On Tue, Oct 22, 2013 at 2:03 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
> As long as you know what you're doing :)
> git push -f
Jed was advocating
  git push origin +barry/myshit
    Matt
> On Tue, Oct 22, 2013 at 3:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    Thanks
>>   Ok, that works but now when I try to push it won't allow. is there some
>> way to force the push (no one is using this branch it is in a pull request
>> and needed cleaning)
>> ~/Src/petsc  barry/reduce-dmsetup-da-memoryusage $ git push
>> To git at bitbucket.org:petsc/petsc.git
>>  ! [rejected]        barry/reduce-dmsetup-da-memoryusage ->
>> barry/reduce-dmsetup-da-memoryusage (non-fast-forward)
>> error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
>> hint: Updates were rejected because the tip of your current branch is
>> behind
>> hint: its remote counterpart. Merge the remote changes (e.g. 'git pull')
>> hint: before pushing again.
>> hint: See the 'Note about fast-forwards' in 'git push --help' for details.
>> On Oct 22, 2013, at 1:55 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
>> > git rebase -i HEAD~2/3
>> > On Tue, Oct 22, 2013 at 2:53 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> >   I would like to put together the last two commits in a branch, how do
>> I do this?
>> >  git rebase -i
>> > doesn't help because it only handles the last commit. How do I tell git
>> to go back one commit in the rebase?
>> >    Thanks
>> >    Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131022/07e641fd/attachment.html>
