[petsc-dev] viewing factored matrices
Fri Nov 22 10:40:20 CST 2013
On Fri, Nov 22, 2013 at 10:33 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Hmm, since under normal usage the factored matrix is owned by one of the
> PCFactor subclass objects do we actually want the PCFactor subclass to
> manage the viewing of them from the command line and not the “Mat” directly
> ? Something like   -pc_factor_mat_view xxx    ?    I think this approach
> would lead to clean simple code, while trying to force it through the
> MatSetFromOptions() to get the viewer would be convoluted since the
> factored matrix may not exist when PCSetFromOptions() is called and
> creating that matrix early (while possible) doesn’t seem the right model. I
> prefer -pc_factor_mat_xxx options rather than -mat_xx options for anything
> related to the factored matrix.
So I assume you would have PCFactor set the prefix of the matrix to
prefix+"pc_factor_" and call MatViewFromOptions() inside the PCView()?
   Matt
>   Sound ok?
>    Barry
> On Nov 22, 2013, at 9:59 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Barry, at some point in your of Mat viewers, factored matrices became
> > disconnected form -mat_view.  PCLU does not call MatSetFromOptions() on
> > the factored matrix and we don't want to do a MatSetFromOptions() on
> > each iteration.  Should MatGetFactor() be restructured to take a Mat
> > that has already been created, so that it can have options set once?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131122/00bb2c53/attachment.html>
