[petsc-dev] reminder about initializing structs
Thu Nov 21 21:40:46 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Since it is not computable presumably it will not produce correct values.
Oh, presumably the compiler inserts initialization code just like
happens when using a later standard.
>    The thing is if we start dropping this stuff in then we cannot use
>    the -std-c89 flag so we cannot consistently check for no c89
>    constructs (or we get warnings all of the code that we cannot
>    distinguish from real warnings.
>     It is a tiny bit of syntactic sugar that is not worth the
>     drawbacks of warnings and or not checking source code so please
>     don’t put it in.
Sure, no problem, it's a minor convenience and I anticipate our language
conservatism (caused by Microsoft) will continue for the near future.
Registration of time integrator tableaus is a place that I recall
getting similar warnings in the past, but where it is more annoying to
list out as assignment statements.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131121/ef4268eb/attachment.sig>
