[petsc-dev] what's q in snes ex62
Fri Nov 15 17:37:14 CST 2013
On Fri, Nov 15, 2013 at 5:31 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Fri, Nov 15, 2013 at 3:21 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Fri, Nov 15, 2013 at 5:09 PM, Geoffrey Irving <irving at naml.us> wrote:
> >> Is the second equation the weak form of incompressibility?  If so, why
> >> isn't q u?  It's used as q several places throughout the code, so it
> >> seems more likely to be my misunderstanding than a typo.
> >>   < \nabla v, \nabla u + {\nabla u}^T > - < \nabla\cdot v, p > + < v, f
> > = 0
> >>   < q, \nabla\cdot v >
>     = 0
> > u, v \in V and p, q \in P, and hopefully \div V = P for stability.
> Are you using the same variables as
> http://fenicsproject.org/documentation/dolfin/dev/python/demo/pde/stokes-iterative/python/documentation.html
> If so, maybe that line should be
>     < q, \nabla\cdot u >
> I.e., "u" instead of "v"?
Damn, you are right.
  Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/8f33029a/attachment.html>
