[petsc-dev] COPTFLAGS
Wed Nov 13 13:43:07 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> If COPTFLAGS is set in argDB [for either bopt= 'g' or 'O'] - the first
> 'if' statement is evaluated -so the 'else' block is never executed.
You're right.  I actually had a debugger in there yesterday before I
wrote this patch, but I did something wrong.  I will abandon this last
commit and merge the other one (being consistent about -O0 for
getCxxFlags and getFortranFlags).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131113/559f3708/attachment.sig>
