[petsc-dev] PetscHashIJ scaling problem?
Mon Nov 11 15:53:17 CST 2013
On Sun, Nov 10, 2013 at 12:47 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Okay, here is the clearly quadratic performance, and its in next. Build
> > SNES ex12 and run using
> > /PETSc3/petsc/petsc-dev/arch-c-opencl-opt-next/lib/ex12-obj/ex12
> -run_type
> > perf -refinement_limit 0.00000625 -variable_coefficient field
> > -petscspace_order 1 -mat_petscspace_order 0 -show_initial 0
> -show_solution
> > 0 -petscfe_type basic -log_summary -interpolate
> > -refinement_limit 0.000625     DMPlexInterpolate       4 1.0 1.7443e-02
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 12  0  0  0 24  12  0  0  0 24     0
> > -refinement_limit 0.0003125    DMPlexInterpolate       4 1.0 3.3111e-02
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 13  0  0  0 24  13  0  0  0 24     0
> > -refinement_limit 0.0000625    DMPlexInterpolate       4 1.0 2.3465e-01
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 21  0  0  0 24  21  0  0  0 24     0
> > -refinement_limit 0.00003125   DMPlexInterpolate       4 1.0 7.7508e-01
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 30  0  0  0 24  30  0  0  0 24     0
> > -refinement_limit 0.000015625  DMPlexInterpolate       4 1.0 2.7267e+00
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 42  0  0  0 24  42  0  0  0 24     0
> > -refinement_limit 0.0000078125 DMPlexInterpolate       4 1.0 1.0175e+01
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 58  0  0  0 24  58  0  0  0 24     0
> > -refinement_limit 0.00000625   DMPlexInterpolate       4 1.0 3.8912e+01
> 1.0
> > 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 72  0  0  0 24  72  0  0  0 24     0
> Testing in optimized mode, I have
> DMPlexInterpolate       4 1.0 2.1803e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01 56  0  0  0 24  56  0  0  0 24     0
> DMPlexStratify         9 1.0 2.0112e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01 52  0  0  0 24  52  0  0  0 24     0
> DMPlexPreallocate       1 1.0 5.3650e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00 14  0  0  0 12  14  0  0  0 12     0
> DMPlexResidualFEM       1 1.0 5.6863e-01 1.0 3.54e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 15 54  0  0  0  15 54  0  0  0     6
> -refinement_limit 0.000005
> DMPlexInterpolate       4 1.0 9.0466e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> DMPlexStratify         9 1.0 8.6705e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01 69  0  0  0 24  69  0  0  0 24     0
> DMPlexPreallocate       1 1.0 1.0999e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00  9  0  0  0 12   9  0  0  0 12     0
> DMPlexResidualFEM       1 1.0 1.1739e+00 1.0 7.08e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  9 54  0  0  0   9 54  0  0  0     6
> -refinement_limit 0.0000025
> DMPlexInterpolate       4 1.0 3.9527e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01 85  0  0  0 24  85  0  0  0 24     0
> DMPlexStratify         9 1.0 3.8794e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01 83  0  0  0 24  83  0  0  0 24     0
> DMPlexPreallocate       1 1.0 2.1816e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00  5  0  0  0 12   5  0  0  0 12     0
> DMPlexResidualFEM       1 1.0 2.4221e+00 1.0 1.42e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  5 54  0  0  0   5 54  0  0  0     6
> These are coming from DMLabelSetValue(), which is O(N) when the point
> does not yet exist.  To insert/modify these entries with storage bounded
> by the number of points rather than the number of times you mutate them,
> either use a hash (perhaps compressing to sorted array later) or a tree.
> (The guy that wrote khash also wrote kbtree, which has the same
> interface, though it tends to use more memory and be slower.)
I rewrote insertion for DMLabel to use the hash table, and convert to flat
arrays after insertion. Now its all linear:
-refinement_limit 0.000625     DMPlexInterpolate       4 1.0 1.1356e-02 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  9  0  0  0 24   9  0  0  0 24     0
-refinement_limit 0.0003125    DMPlexInterpolate       4 1.0 2.2995e-02 1.0
-refinement_limit 0.0000625    DMPlexInterpolate       4 1.0 9.0071e-02 1.0
-refinement_limit 0.00003125   DMPlexInterpolate       4 1.0 1.7823e-01 1.0
-refinement_limit 0.000015625  DMPlexInterpolate       4 1.0 3.7626e-01 1.0
-refinement_limit 0.0000078125 DMPlexInterpolate       4 1.0 8.7979e-01 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 11  0  0  0 24  11  0  0  0 24     0
-refinement_limit 0.00000625   DMPlexInterpolate       4 1.0 1.7574e+00 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 10  0  0  0 24  10  0  0  0 24     0
Time (sec):           1.275e-01      1.00000   1.275e-01
Time (sec):           2.476e-01      1.00000   2.476e-01
Time (sec):           9.859e-01      1.00000   9.859e-01
Time (sec):           1.993e+00      1.00000   1.993e+00
Time (sec):           4.032e+00      1.00000   4.032e+00
Time (sec):           8.257e+00      1.00000   8.257e+00
Time (sec):           1.674e+01      1.00000   1.674e+01
This should help Karl running his GPU test now :)
   Matt
> https://github.com/attractivechaos/klib/blob/master/kbtree.h
> If you run in a debugger, you'll find that your stack is pretty much
> always here:
> (gdb) bt
> #0  0x00007ffff51314be in __memmove_ssse3_back () from /usr/lib/libc.so.6
> #1  0x00007ffff751bca4 in PetscMemmove (a=0x26a0030, b=0x26a002c,
> n=979520) at src/sys/utils/memc.c:94
> #2  0x00007ffff78f51b6 in DMLabelSetValue (label=0x4529b0, point=404548,
> value=<optimized out>) at src/dm/impls/plex/plexlabel.c:279
> #3  0x00007ffff78ad27f in DMPlexStratify (dm=0x429350) at
> src/dm/impls/plex/plex.c:1440
> #4  0x00007ffff78e8b63 in DMPlexInterpolateFaces_Internal
> (cellDepth=<error reading variable: Cannot access memory at address 0x2>,
> dm=<optimized out>, idm=<optimized out>) at
> src/dm/impls/plex/plexinterpolate.c:290
> #5  DMPlexInterpolate (dm=0x428370, dmInt=0x7fffffffbda0) at
> src/dm/impls/plex/plexinterpolate.c:331
> #6  0x00007ffff78a629a in DMPlexCreateFromCellList (comm=<optimized out>,
> dim=<optimized out>, numCells=262144, numVertices=131585,
> numCorners=<optimized out>, interpolate=<optimized out>, cells=<optimized
> out>, spaceDim=40501292, vertexCoords=0x26ac3a4, dm=0x7fffffffc520) at
> src/dm/impls/plex/plexcreate.c:945
> #7  0x00007ffff78ba14d in DMPlexRefine_Triangle (dm=<optimized out>,
> maxVolumes=0x42e9f0, dmRefined=0x7fffffffc520) at
> src/dm/impls/plex/plex.c:3639
> #8  0x00007ffff78baae0 in DMRefine_Plex (dm=0x42cb40, comm=40501292,
> dmRefined=0x7fffffffc520) at src/dm/impls/plex/plex.c:4313
> #9  0x00007ffff791d9cc in DMRefine (dm=0x42cb40, comm=40501292,
> dmf=0x7fffffffc520) at src/dm/interface/dm.c:1498
> #10 0x0000000000404c64 in CreateMesh (comm=1140850688,
> user=0x7fffffffc608, dm=0x7fffffffd740) at
> /home/jed/petsc/src/snes/examples/tutorials/ex12.c:311
> #11 0x0000000000406e60 in main (argc=21, argv=0x7fffffffd858) at
> /home/jed/petsc/src/snes/examples/tutorials/ex12.c:648
> DMPlexStratify also calls ISGetIndices, but forgets ISRestoreIndices.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131111/ac08eec0/attachment.html>
