[petsc-dev] where are nightly build configures?
Sun Nov 10 15:23:50 CST 2013
On Nov 10, 2013, at 3:16 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hey,
> adding the links is no problem. The alternative is to access the directory via FTP:
> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/10/
> Do you also want to have some error or warning counting? This could be fairly tricky to exclude those triggered by external packages, as there are many errors/warnings reported from the compilation of external packages included. For example,
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/10/configure_next_arch-linux-pkgs-threadcomm_thrash.log
   There should be a list and then a simple Failed Succeeded check on the right instead of a list of errors.
    Thanks
    Barry
> is a mess...
> Best regards,
> Karli
> On 11/10/2013 09:58 PM, Barry Smith wrote:
>>   http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/10/  has links to the make, make examples and “build” outputs but doesn’t have links to the configure.log for each case. Can these please be added?
>>    Thanks
>>    Barry
