[petsc-dev] stencils, ex2f.F, openmp
Gryllida gryllida at fastmail.fm
Thu Nov 7 21:38:27 CST 2013
On Fri, 8 Nov 2013, at 10:09, Svetlana Tkachenko wrote:
> ex2f.F involves a band matrix with 4 on main diagonal and -1s on the sub-diagonals. I have A_central matrix which stores the -4s, and A_left, A_right, Atop, A_bottom matrices which store the -1s (they actually are more complicated numbers than that). Would it be recommended to simply wrap the "do 10, II=..." block like the one in ex2f.F into $OMP DO to speed up filling of the matrix as each of the values set can be set independently of others? (I tried doing so but got a segmentation fault and I'm working on a small example to reproduce the problem.)
>   Svetlana
I figured out this is called 'stencils' correctly and corrected the subject.
Trying to use example ex22f.F but it's quite involved.
  Svetlana
