[petsc-dev] make all PETSc Fortran examples modern freeform?
Thu Nov 7 09:07:43 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> On Thu, 7 Nov 2013, Blaise A Bourdin wrote:
>> I haven’t use fixed-form in a long time, but isn’t free-form a superset of fixed-form?
> In essence all current petsc code complies with this.
> [i.e its syntactically corect both free form and fixed form]
Current PETSc requires polyglot Fortran, written in a peculiar
intersection of the two dialects.
>> Are there situation where a fixed form code cannot be compiled as free form source code?
> Not sure if its the fixed/free form issue - [its perhaps f77 vs f90] - some
> external packages use 'C' for comment - which some f90 compilers barf on.
c      = 1
is a valid statement in free-form, but a comment in fixed-form.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131107/a7890ffb/attachment.sig>
