[petsc-dev] MatGetBlockSize[s]() before prellocation
Lisandro Dalcin dalcinl at gmail.com
Sun Nov 3 03:19:10 CST 2013
On 1 November 2013 19:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 1, 2013, at 10:56 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Lisandro Dalcin <dalcinl at gmail.com> writes:
>>> Currently, MatGetBlockSize[s]() fails before matrix preallocation
>>> because of the check MatCheckPreallocated(mat,1). Are there any
>>> objections to remove that check?
>> This is fine with me.
>    Presumably if it has not been set yet it would return -1 and that would be documented?
https://bitbucket.org/petsc/petsc/pull-request/117/allow-calling-matgetblocksize-s-before/diff
Barry, are you happy with the notes in the doc section?
Lisandro Dalcin
CIMEC (UNL/CONICET)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1016)
Tel/Fax: +54-342-4511169
