[petsc-dev] PETSc developers who use weird MPI
Sat Nov 2 14:34:22 CDT 2013
On Fri, 1 Nov 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > On Fri, 1 Nov 2013, Satish Balay wrote:
> >> >    The reason I had to merge all that stuff into saws was that saws
> >> >    could not merge into next because those branches so changed
> >> >    next. I had to merge them into saws before I could get saws into
> >> >    next.
> Peter forgot what had been released to 'next' and rebased after merging,
> leading to two copies of the earlier commits.  I think that is the
> reason for much of this confusion.
Should 'prbrune/sf-sfbasicops' and 'prbrune/mat-matcolor' be cleaned
up to remove the merge between the 'rebased' and 'non-rebased'
variants of the branches - before the changes got into master?
Satish
