[petsc-dev] PETSc developers who use weird MPI
Peter Brune prbrune at gmail.com
Fri Nov 1 21:36:20 CDT 2013
Did you rebase prbrune/sf-sfbasicops?  I get odd merges.
- Peter
On Fri, Nov 1, 2013 at 9:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 1 Nov 2013, Satish Balay wrote:
> > Somehow the snapshot of 'prbrune/sf-sfbasicops' [prior to my fix] got
> merged into 'barry/saws'
> > [I'll have to check these branches to see the path.]
> > The fix is to merge latest 'prbrune/sf-sfbasicops' in the same pathway
> it got into 'barry/saws'
> Ok the branches that have the offending commit:
> balay at mockingbird /home/balay/petsc (barry/saws)
> $ git branch -r --contains 53deab3
>   origin/barry/saws
>   origin/madams/sr-driver
>   origin/next
>   origin/prbrune/fas-gscolorsecant
>   origin/prbrune/mat-matcolor
>   origin/prbrune/sf-sfbasicops
> Now see which of of the above branches got merged to 'barry/saws'
> $ git log --merges --oneline |head
> d548240 Merge branch 'prbrune/mat-matcolor' into barry/saws
> fcaff9f Merge branch 'jed/check-pointer-runtime' into barry/saws
> 7737a22 Merge branch 'master' into barry/saws
> ad7c120 Merge branch 'knepley/feature-test-parser'
> b4a5846 Merge branch 'prbrune/snes-qnscaling'
> f5cedc2 Merge branch 'knepley/feature-plex-refine-3d'
> 1fa8f14 Merge branch 'knepley/feature-plex-reordering'
> dc1b40d Merge branch 'maint'
> 7390fa2 Merge branch 'balay/configure-winpython-check' into maint
> 39481a4 Merge branch 'balay/add-newline-between-stdout-stderr' into maint
> Looks like Barry merged 'prbrune/mat-matcolor' into 'barry/saw'
> balay at mockingbird /home/balay/petsc (prbrune/mat-matcolor)
> 70ec7f0 Merge branch 'prbrune/sf-sfbasicops' into prbrune/mat-matcolor
> 16407d4 Merge branch 'master' into prbrune/mat-matcolor
> 76ef003 Merge branch 'jed/datafiles-inherit'
> 35132eb Merge branch 'jed/dmvecmattypes-stdcoords'
> 7f96713 Merge branch 'jed/options-insert-bcast-bgq'
> 13cbb55 Merge branch 'jed/avoid-getpwuid'
> b15a537 Merge branch 'knepley/fix-windows-download'
> 2c3e1d3 Merge branch 'balay/__float128-fix-download-f2cblas-mesg'
> 7a7ac0e Merge branch 'maint'
> a04acb8 Merge branch 'jed/fix-fieldsplit-mg-example'
> Ok peter merged the 'prbrune/sf-sfbasicops' snapshot prior to my fix
> into 'prbrune/mat-matcolor'
> ok prbrune/sf-sfbasicops -> prbrune/mat-matcolor -> barry/saws
> So the fix is to do the same merges with the latest prbrune/sf-sfbasicops
> Peter?
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131101/cbac1944/attachment.html>
