[petsc-dev] PETSc developers who use weird MPI
Fri Nov 1 17:03:36 CDT 2013
   please always test with mpiuni before pushing when you use weird MPI
src/vec/is/sf/impls/basic/sfbasic.c: In function ‘PetscSFBasicPackGetUnpackOp’:
src/vec/is/sf/impls/basic/sfbasic.c:594:18: error: ‘MPI_PROD’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:594:18: note: each undeclared identifier is reported only once for each function it appears in
src/vec/is/sf/impls/basic/sfbasic.c:597:18: error: ‘MPI_LAND’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:598:18: error: ‘MPI_BAND’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:599:18: error: ‘MPI_LOR’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:600:18: error: ‘MPI_BOR’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:601:18: error: ‘MPI_LXOR’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c:602:18: error: ‘MPI_BXOR’ undeclared (first use in this function)
src/vec/is/sf/impls/basic/sfbasic.c: In function ‘PetscSFBasicPackGetFetchAndOp’:
   It is frustrating to get this kind of crap all the time after pulling.
   Thanks
    Barry
