[petsc-dev] headsup: default externalpackages dir is now PETSC_DIR/PETSC_ARCH/externalpackages
Fri Nov 1 11:16:41 CDT 2013
Just a headsup.
With the latest 'master' branch - the location of externalpackages is
changed from PETSC_DIR/externalpackages to
PETSC_DIR/PETSC_ARCH/externalpackages.
So if you rerun configure on master branch - this new location will be used.
Satish
