[petsc-dev] spectral deferred correction (SDC) time stepper
Matthew Emmett memmett at gmail.com
Wed May 29 15:44:59 CDT 2013
On Wed, May 29, 2013 at 1:37 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Emmett <memmett at gmail.com> writes:
> > Ideally I think it would be nice if the user could just add "-ts_type
> sdc"
> > and have the code figure out which SDC variant (explicit, implicit, or
> > imex) to use.  The trouble I am having is that a users RHSFunction can be
> > recast into implicit form by TSComputeIFunction if an implicit
> time-stepper
> > is used... which means that I can't just check whether RHSFunction has
> been
> > registered to switch between explicit only and implicit only.
> TSGetRHSFunction() should return NULL if the user did not set an
> RHSFunction, however, many stiff systems are described using RHSFunction
> as a matter of convenience, and because in some parameter regimes, they
> may be non-stiff.
OK, understood.
> > Is there a preferred way of doing this, or should I add another option
> > to select which SDC variant to use?
> I would use an option for this.  The user likely wants to try both for
> moderately stiff systems.
> If you would like comments on your code and general approach, please
> push it in a fork on bitbucket or github.
Will do -- I will tidy up a few things and make the history a bit more sane
first.
Thanks for your comments,
Matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130529/14346a30/attachment.html>
