[petsc-dev] Experimental GNU make build system
Wed May 29 00:24:40 CDT 2013
ok - pushed this commit - and the removal of __SDIR__ to
'balay/remove-sdir' [which is branched off 'jed/gnumake']
The SDIR removal affects quiet a few routines - and a few
structures. And its probable I missed fixed something [or fixed
something incorrectly that the compiler didn't catch]
Basic builds run fine.
commit 4a020275677b3c7c915947a9a8df98db6a86b95d
Author: Satish Balay <balay at mcs.anl.gov>
Date:   Wed May 29 00:11:17 2013 -0500
    __SDIR__: remove usage of __SDIR__ from PETSc sources.
commit ef9cb020c7e6703c909e2bfcf036c7598315ce88
Date:   Wed May 29 00:09:35 2013 -0500
    __SDIR__: fix all-legacy targets to use ${PWD} instead of LOCDIR/__INSDIR in compiles
Satish
On Tue, 28 May 2013, Satish Balay wrote:
> On Thu, 23 May 2013, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > > __SDIR__ is primarily needed by 'all-legacy'. cmake/gmake builds are
> > > using the full paths at compile time - so they don't need it [and are
> > > using empty LOCDIR]
> > This should take care of all-legacy:
> > diff --git i/conf/rules w/conf/rules
> > index 0fc01dc..f8b70ad 100644
> > --- i/conf/rules
> > +++ w/conf/rules
> > @@ -391,7 +391,7 @@ getautoconfargs:
> >          if [ $${mypwd} != $${newpwd} ]; then \
> >           ${OMAKE}  PETSC_ARCH=${PETSC_ARCH}  chk_petscdir;\
> >          fi
> > -       ${PETSC_COMPILE_SINGLE} $<
> > +       ${PETSC_COMPILE_SINGLE} ${PWD}/$<
> >         @if [ "${PETSCPORTABLE}" != "" ]; then \
> >            ${PYTHON} ${PETSC_DIR}/bin/portabilitycheck.py $*.o ; \
> >          fi
> I guess fortran sources don't need __SDIR__ - so the corresponding
> targets don't need changes.
> And we can use the following to get libfast working [This works with
> solaris-make & bsd-make aswell]
> PSOURCEC  = $(SOURCEC:%=${PWD}/%)
> I did a basic buid withe the following [checked on
> linux,solaris,windows] - and it appears to work fine [assuming
> "unknowndirectory/" stuff will be removed with other __SDIR__ changes]
> 2 Differences are [these should be ok]:
> - full path listed in error messages.
> '/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c'
> [ vs previous message with 'src/ksp/pc/interface/pcset.c']
> - The compilers now spit out the full file names. [as thats what we pass to them]
> libfast in: /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/view.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/flush.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewregall.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewreg.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewa.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/dlregispetsc.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewers.c:
> /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/dupl.c:
> libfast in: /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/ftn-auto
> Satish
> petsc at n-gage:~/petsc.clone/src/ksp/ksp/examples/tutorials$ ./ex2 -pc_type foobar
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing external package needed for type:
> see http://www.mcs.anl.gov/petsc/documentation/installation.html#external!
> [0]PETSC ERROR: Unable to find requested PC type foobar!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.4.0, unknown
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex2 on a arch-opensolaris-pkgs-opt named n-gage by petsc Tue May 28 20:37:00 2013
> [0]PETSC ERROR: Libraries linked from /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/lib
> [0]PETSC ERROR: Configure run at Tue May 28 13:25:16 2013
> [0]PETSC ERROR: Configure options --with-debugger=/bin/true --with-debugging=0 --download-mpich=1 --with-c2html=0 --download-cmake=1 --download-metis=1 --download-parmetis=1 --download-triangle=1 --download-superlu=1 --download-superlu_dist=1 --download-f-blas-lapack=1 --download-scalapack=1 --download-mumps=1 --download-sundials=1 --download-hypre=1 --download-umfpack=1 --download-chaco=1 --download-spai=1 --with-no-output -PETSC_ARCH=arch-opensolaris-pkgs-opt -PETSC_DIR=/export/home/petsc/petsc.clone
> [0]PETSC ERROR: PCSetType() line 68 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c
> [0]PETSC ERROR: PCSetFromOptions() line 163 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c
> [0]PETSC ERROR: KSPSetFromOptions() line 357 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/ksp/interface/itcl.c
> [0]PETSC ERROR: main() line 192 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/ksp/examples/tutorials/ex2.c
> application called MPI_Abort(MPI_COMM_WORLD, 86) - process 0
> [unset]: aborting job:
> diff --git a/conf/rules b/conf/rules
> index 0fc01dc..64ff8d8 100644
> --- a/conf/rules
> +++ b/conf/rules
>          fi
>          fi
> @@ -399,16 +399,16 @@ getautoconfargs:
>  #   Compiles CUDA code
>  .cu.o:
> -	${PETSC_CUCOMPILE_SINGLE} $<
> +	${PETSC_CUCOMPILE_SINGLE} ${PWD}/$<
>  .cu.a:
>  	-${AR} ${AR_FLAGS} ${LIBNAME} $*.o
>  	-if test -n "${LIBTOOL}"; then ${AR} ${AR_FLAGS} ${LT_LIBNAME} $*.lo; fi
>  	-${RM} $*.o $*.lo
>  .c.a .cpp.a .cc.a .C.a:
> -	-${PETSC_COMPILE_SINGLE} $<
> +	-${PETSC_COMPILE_SINGLE} ${PWD}/$<
>  	-${RM} $*.o $*.lo
> diff --git a/conf/variables b/conf/variables
> index 79ce8ba..bd65385 100644
> --- a/conf/variables
> +++ b/conf/variables
> @@ -10,7 +10,7 @@
>  PETSC_LIB_DIR	     = ${PETSC_DIR}/${PETSC_ARCH}/lib
> -PETSC_CCPPFLAGS	    = ${PETSC_CC_INCLUDES} ${PETSCFLAGS} ${CPP_FLAGS} ${CPPFLAGS} -D__INSDIR__=${LOCDIR}
> +PETSC_CCPPFLAGS	    = ${PETSC_CC_INCLUDES} ${PETSCFLAGS} ${CPP_FLAGS} ${CPPFLAGS}
>  PETSC_FCPPFLAGS	    = ${PETSC_FC_INCLUDES} ${PETSCFLAGS} ${FPP_FLAGS} ${FPPFLAGS}
>  PETSC_C_SH_LIB_PATH = ${CC_LINKER_SLFLAG}${PETSC_LIB_DIR}
>  PETSC_F_SH_LIB_PATH = ${FC_LINKER_SLFLAG}${PETSC_LIB_DIR}
> @@ -30,10 +30,12 @@ F_SH_LIB_PATH	= ${PETSC_F_SH_LIB_PATH}
>  # The following variables define PETSc compile procedures
> -PETSC_COMPILE         = ${PCC} -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}  ${SOURCEC}
> +PSOURCEC  = $(SOURCEC:%=${PWD}/%)
> +PSOURCECU = $(SOURCECU:%=${PWD}/%)
> +PETSC_COMPILE         = ${PCC} -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}  ${PSOURCEC}
>  PETSC_COMPILE_SINGLE  = ${PCC} -o $*.o -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}
>  PETSC_FCOMPILE        = ${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS}  ${SOURCEF}
> -PETSC_CUCOMPILE       = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}" ${SOURCECU}
> +PETSC_CUCOMPILE       = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}" ${PSOURCECU}
>  PETSC_CUCOMPILE_SINGLE= ${CUDAC} -o $*.o ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}"
>  # define OBJSC and OBJSF OBJSCU
