[petsc-dev] MatTranspose_MPIAIJ broken
Sun May 26 10:25:10 CDT 2013
"Mark F. Adams" <mark.adams at columbia.edu> writes:
> madams/petsc> grep PETSC_HAVE_MPI_COMBINER_DUP ./arch-xc30-opt/include/petscconf.h
> #ifndef PETSC_HAVE_MPI_COMBINER_DUP
> #define PETSC_HAVE_MPI_COMBINER_DUP 1
This should be fine.
> I can't reproduce this problem on my Mac with ex56.  This error was on
> Edison at NERSc.  The new Cray.
> I'll try rebuilding everything from scratch to double check.
Let me know if this works.  If not, I can help set up a reduced test
case.  It would be helpful to see how control flow goes through
MPIPetsc_Type_compare.
