[petsc-dev] synchronized printing, singletons, and jumbled GAMG/BJacobi output
Sat May 25 21:34:44 CDT 2013
On May 25, 2013, at 9:06 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> Instead, it
>>> uses block Jacobi in which all blocks but one are empty.
>>   This seems a rather ad hoc way of handling it. Why not have a
>>   proper mechanism for telescoping solvers rather than an ad hoc
>>   block Jacobi with 0 sizes on most blocks?
> How would that "proper mechanism" look?
   Beats me, I didn't write this solver infrastructure but it must be possible to design a reasonable infrastructure to handle this kind of thing. If it is not possible then MPI sucks.
>>>> And why does it have different solvers on each process?
>>> It doesn't, but it calls PCBJacobiGetSubKSP() so as to configure the
>>> inner PC to be PCLU, but PCBJacobiGetSubKSP conservatively sets this
>>> flag:
>>> jac->same_local_solves = PETSC_FALSE;        /* Assume that local solves are now different;
>>>                                                 not necessarily true though!  This flag is
>>>                                                 used only for PCView_BJacobi() */
>>   Why not just fix this instead. Fix it so it doesn't set the flag in this situation.
> Sure, where would we set that flag?  Or, how do we compare solvers (on
> different subcomms) for "equivalent" configuration?
      /* coarse grid */
      KSP smoother,*k2; PC subpc,pc2; PetscInt ii,first;
      Mat Lmat = Aarr[(level=pc_gamg->Nlevels-1)]; lidx = 0;
      ierr = PCMGGetSmoother(pc, lidx, &smoother);CHKERRQ(ierr);
      ierr = KSPSetOperators(smoother, Lmat, Lmat, SAME_NONZERO_PATTERN);CHKERRQ(ierr);
      ierr = KSPSetNormType(smoother, KSP_NORM_NONE);CHKERRQ(ierr);
      ierr = KSPGetPC(smoother, &subpc);CHKERRQ(ierr);
      ierr = PCSetType(subpc, PCBJACOBI);CHKERRQ(ierr);
      ierr = PCSetUp(subpc);CHKERRQ(ierr);
      ierr = PCBJacobiGetSubKSP(subpc,&ii,&first,&k2);CHKERRQ(ierr);
      if (ii != 1) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_PLIB,"ii %D is not one",ii);
      ierr = KSPGetPC(k2[0],&pc2);CHKERRQ(ierr);
      ierr = PCSetType(pc2, PCLU);CHKERRQ(ierr);
      ierr = PCFactorSetShiftType(pc2,MAT_SHIFT_INBLOCKS);CHKERRQ(ierr);
      ierr = KSPSetTolerances(k2[0],PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT,1);CHKERRQ(ierr);
   The code is already completely hardwired to use block Jacobi and LU so for maint I would just hardwire setting the flag here to same . That's right, just #include <../src/ksp/pc/impls/bjacobi/bjacobi.h> and go to town.  In the future the code can be refactored to not use an ad hoc bjacobi to manage the telescoping.
   Barry
