[petsc-dev] synchronized printing, singletons, and jumbled GAMG/BJacobi output
Sat May 25 08:14:03 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
>> 2. Buffer and then synchronize on PetscViewerRestoreSingleton.  This
>>    requires adding PetscViewerASCIISynchronizedVPrintf so that normal
>>    PetscViewerASCIIPrintf on the singleton viewer will write to a
>>    string.
> I would rather replace the writes with SynchronizedPrintf()s. Why change the
> semantics?
    PetscViewerGetSingleton(v,&s);
    PetscViewerASCIISynchronizedPrintf(s,"This is supposed to be synchronous on 'v', not 's'\n");
    KSPView(subksp,s);
    PetscViewerRestoreSingleton(v,&s);
The true problem is with calling KSPView, but I think the Printf is also
misleading.
