[petsc-dev] Can someone explain what is going on here?
Tue May 21 07:46:25 CDT 2013
https://bitbucket.org/petsc/petsc/src/ff331c249a8bbf694711b310f25fec0e839b33db/src/ksp/ksp/interface/itfunc.c?at=master#cl-202
Dave has a DMComposite which he splits using FS, but then he wants
to use GMG on the velocity block. He manually sets the DM, but this
wipes out the matrix which FS set there.
Do we have a clear explanation of what setting a DM on the solver does?
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130521/055ffbd6/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130521/055ffbd6/attachment.obj>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130521/055ffbd6/attachment.bin>
