[petsc-dev] Experimental GNU make build system
Mon May 20 22:59:18 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    That is should not require a rewrite, merely some minor changes to remove the Unixisms.
I think a sizable fraction of the code is full of those unixisms.
