[petsc-dev] FAQ typo fixes (test pull request)
Patrick Sanan psanan at cms.caltech.edu
Sun May 19 20:26:49 CDT 2013
I fixed a couple of things in the faq - a few small typos and the out of date gfortran info for OS X.  This only affects one file (faq.html), but as a test run I thought I'd submit a pull request anyway. If it's easier to work with a patch, I've attached one to this email.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130519/6da8e9fb/attachment.obj>
