[petsc-dev] MatSetColoring
Peter Brune prbrune at gmail.com
Sat May 18 09:32:36 CDT 2013
It's already in the patch!
- Peter
On Fri, May 17, 2013 at 4:22 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Peter Brune <prbrune at gmail.com> writes:
> > The example that caused me to go into this in the first place was
> > snes/examples/tutorials/ex45.c, which a) set the user context, then
> > manually set the Jacobian func to SNESComputeJacobianDefaultColor and b)
> > seems to have disappeared, so I'm on board with this.
> If there is not any more, there should be one example (could be a test)
> that sets a user-provided coloring.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130518/4d08fb73/attachment.html>
