[petsc-dev] MatSetColoring
Fri May 17 16:09:51 CDT 2013
Peter Brune <prbrune at gmail.com> writes:
> Yeah it was pretty easy to break in TS..  I thought that I might be going
> in circles here.
>> It's probably worth risking the low-probability of a user depending on
>> the parameter being ignored in exchange for being able to fix this
>> inconvenience in petsc-3.4.
> What exactly do you mean by this?  I can "fix it" for the TS case by
> replacing the error-out on the parameter with a type compare, but for a
> general user context that's not a PetscObject it's more dicey.  We could
> zero it out explicitly when setting snes_fd_coloring from options
If at all possible, I think it _should_ be zeroed by -snes_fd_coloring.
> and expect users to do the right thing.
That was the point of my comment.  We don't think they are in the same
position as -snes_fd_coloring, but all their old code either passed NULL
or passed a valid MatFDColoring or passed NULL, and it's not very useful
to write new code that passes non-NULL.
