[petsc-dev] MatSetOption is logically collective even for MAT_ROW_ORIENTED.
Patrick Lacasse patrick.m.lacasse at gmail.com
Thu May 16 13:45:53 CDT 2013
Hi Barry,
   is MatSetOption still logically collective?
Shouldn't  this code :
     if (op > 0) PetscValidLogicalCollectiveEnum(mat,op,2);
     PetscValidLogicalCollectiveBool(mat,flg,3);
be :
     if (op > 0) {
Could this be part of the next release patch?
thks,
Patrick
2012/10/4 Barry Smith <bsmith at mcs.anl.gov>
>   Fixed, supposedly in petsc-dev
> On Sep 26, 2012, at 1:47 PM, Patrick Lacasse <patrick.m.lacasse at gmail.com>
> wrote:
> > Thanks Barry for your answer,
> > Patrick
> > 2012/9/20 Barry Smith <bsmith at mcs.anl.gov>
> >    Patrick,
> >     We may have gone overboard with our assertions in this routine.
> >     Some MatOptions really should be collective while others like the
> one you are using need not be collective.
> >     Simple solution just remove those two collective asserts.  Harder
> solution, use the asserts for only the options that should be checked. We
> could for example use less then some number for collective asserts and
> greater than number for for non collective. A little hacky but would work?
> >    Barry
> > On Sep 20, 2012, at 11:42 AM, Patrick Lacasse <
> patrick.m.lacasse at gmail.com> wrote:
> > > Hi,
> > >     I just discovered that the way we assemble our matrix cause a
> deadlock in MatSetOption
> > > when petsc is compiled with debugging option enabled.
> > > I resume :
> > > - We loop over elements.
> > > - For each element we create a small elementary matrix.
> > > - We assemble the elementary matrix with MatSetValues into the big one.
> > > Sometimes, we have some rectangular elementary matrix that needs to be
> added twice,
> > > the second time it is transposed. The big matrix is not symmetric for
> many possible reasons.
> > > We are essentially doing it for every elementary matrix that needs it :
> > > MatSetOption(mat,MAT_ROW_ORIENTED,true)
> > > MatSetValues(...)
> > > MatSetOption(mat,MAT_ROW_ORIENTED,false)
> > > MatSetValues(...)
> > > Of course, it fails (deadlock) in MatSetOption at assertion
> > > because different process don't loop over the same (number of)
> elements.
> > > However, it is working fine without the assertion.
> > > I have two question :
> > > Is there really a risk to call MatSetOption(mat, MAT_ROW_ORIENTED,
> flg) on only one process?
> > > What can I do now?
> > > Some possible answer are
> > > - Close our eyes and stop compiling petsc with debugging option
> enabled.
> > > - We could copy our elementary matrix into a transposed one before to
> MatSetValues. We don't want do this cause we think it would slow down our
> code.
> > > - Could MatSetValues has a bonus argument row_oriented?
> > > - Could the assertions in MatSetOption be skipped for some options?
> > > - Could we add a function MatSetRowOriented which would not be
> collective?
> > > thanks,
> > > Patrick Lacasse
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130516/e5e2c273/attachment.html>
