[petsc-dev] Branch 'next' has been rewound
Wed May 15 14:01:39 CDT 2013
On Mon, 13 May 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> == Users ==
> >> I have rewound the branch 'next' after the release, so it will
> >> not fast-forward (just this once).  If you have a local 'next' branch,
> >> you should abandon it and check out a fresh one.  You can do this with
> >>   $ git checkout master
> >>   $ git branch -D next   # delete the old branch
> >>   $ git pull
> >>   $ git checkout next    # revisit 'next' if you want
> >> If you are tracking 'master', 'git pull' will be sufficient.
> > hm. looks like I'll have to do this for all nightlybuild repos.  Is it
> > ok to do it always everynight [and not just during release]?
> Yes, it's fine, but since you only need to check out states from
> upstream, you could just use 'git checkout origin/${BRANCH}' (giving you
> a detached HEAD -- nice for this sort of scripting where you have no use
> for "branch semantics").
> diff --git i/bin/maint/startnightly w/bin/maint/startnightly
> index e48bfe3..ace1ffc 100755
> --- i/bin/maint/startnightly
> +++ w/bin/maint/startnightly
> @@ -21,7 +21,7 @@ foreach TEST ($*)
>        endif
>      endif
>      echo "Cleaning and updating clone at $USR@$MACH $LOC"
> -    $SSH $USR@$MACH $DASHN "cd $LOC ; git checkout -f ${BRANCH}; git pull -q "
> +    $SSH $USR@$MACH $DASHN "cd $LOC ; git fetch -q origin; git checkout -f origin/${BRANCH} "
>    else
>      rsync -e ssh -az --delete  $pdir/ ${USR}@${MACH}:${LOC}
>    endif
Looks like 'git pull' might not work for a detached head. Is there an
easy way to also have 'git pull' work?
thanks,
Satish
> > $ git diff
> > diff --git a/bin/maint/startnightly b/bin/maint/startnightly
> > index e48bfe3..a9b31a1 100755
> > --- a/bin/maint/startnightly
> > +++ b/bin/maint/startnightly
> > @@ -21,7 +21,11 @@ foreach TEST ($*)
> >        endif
> >      endif
> > +    if ("${BRANCH}" == "master") then
> > +      $SSH $USR@$MACH $DASHN "cd $LOC ; git checkout -f ${BRANCH}; git pull -q "
> > +    else
> > +      $SSH $USR@$MACH $DASHN "cd $LOC ; git checkout -f master; git branch -D ${BRANCH}; git pull -q ; git checkout -f  ${BRANCH}"
> > +    endif
> >    else
> >    endif
