[petsc-dev] Branch 'next' has been rewound
Tue May 14 07:41:09 CDT 2013
Jed Brown <jedbrown at mcs.anl.gov> writes:
> == Users ==
> I have rewound the branch 'next' after the release, so it will
> not fast-forward (just this once).  If you have a local 'next' branch,
> you should abandon it and check out a fresh one.  You can do this with
>   $ git checkout master
>   $ git branch -D next   # delete the old branch
>   $ git pull
>   $ git checkout next    # revisit 'next' if you want
If you forget to do the above, you will see something like this the next
time you switch to 'next':
  $ git checkout next
  Switched to branch 'next'
  Your branch and 'origin/next' have diverged,
  and have 324 and 30 different commits each, respectively.
In this case, one command will get you onto the new 'next':
  $ git reset --hard origin/next
