[petsc-dev] Branch 'next' has been rewound
Mon May 13 22:08:08 CDT 2013
On Mon, May 13, 2013 at 10:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Mon, May 13, 2013 at 8:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> >> == Users ==
> >> I have rewound the branch 'next' after the release, so it will
> >> not fast-forward (just this once).  If you have a local 'next' branch,
> >> you should abandon it and check out a fresh one.  You can do this with
> >>   $ git checkout master
> >>   $ git branch -D next   # delete the old branch
> >>   $ git pull
> >>   $ git checkout next    # revisit 'next' if you want
> >> If you are tracking 'master', 'git pull' will be sufficient.
> >> == Developers ==
> >> With v3.4 tagged, we can decide what to do with the branches left over
> >> from 'next' (now in a temporary 'next-pre-3.4' that will be deleted).
> >> If they should be rebased, it's best to do it now.
> >>   $ git checkout my/branch
> >>   $ git rebase v3.4
> >>   $ git push -f --dry-run # should show force-update to your branch
> only,
> >> then remove '--dry-run'
> >> If you like everything in the branch, but there are conflicts, you can
> >> sync with v3.4 now [1].
> >>   $ git merge v3.4
> >>   $ git push
> >> Here is a status summary for the branches that used to be in 'next':
> >> e8577e4 2013-04-10 (karlrupp/feature-viennacl) ViennaCL: fix LOCDIR
> >>   This has a simple conflict with 'knepley/remove-sieve' (below) in
> >>   src/vec/vec/interface/vecregall.c
> >> b61a8fb 2013-03-15 (klaij/fieldsplit-simple-ex70) SNES ex70.c: free
> array
> >> returned by PCFieldSplitGetSubKSP()
> >>   This example highlights a bug/feature request in fieldsplit.  If it
> >>   can be handled without interface changes, it should go to 'maint'.
> >> a05fad5 2013-05-12 (knepley/remove-sieve) DMPlex: remove bad "DMMESH"
> >> documentation
> >>   This branch is a bit chaotic and could reasonably be rebased and have
> >>   the incomplete commits squashed together.
> >> 1cf896f 2013-03-22 (knepley/solkx) SNES ex75: Added Maple verification
> >> test, and added preliminary FEM test
> >>   This branch contains one commit (a9ffcdab03f) that is unrelated and
> >>   made it into v3.4 in a different form (3e298deff27), so rebasing would
> >>   make it cleaner.
> > These two have been rebased and pushed.
> You didn't use 'push -f' as in my instructions above, so you created a
> new merge commit containing both the old and new versions of the
> commits, instead of replacing the old commits with the rebased versions.
For the first one I mistakenly read the lower instructions (knepley/solkx),
but I fixed that with
the second one.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130513/78613420/attachment.html>
