[petsc-dev] testing: with parmetis, without 64-bit, without complex
Mon May 13 13:08:48 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
>   a) Switch the nightlies from make to Python
Are you talking about compilation or running tests?  Compilation should
be irrelevant because all systems should produce the same result.  I
think testing is higher priority.
>   b) Change the categories to tags
Yeah, just can't do this within the current make-based running system.
>   c) Simply parse parts of the output for numerical comparison
It's useful to compare everything because otherwise, new clutter can
show up unintentionally and won't be caught by testing.
