[petsc-dev] removing sieve
Sun May 12 10:53:53 CDT 2013
On Sat, May 11, 2013 at 6:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matt, I take it that you intend for this removal to be merged for
> petsc-3.4 so that users are not distracted by something we aren't
> supporting.  An alternative would be to add a #warning to petscdmmesh.h.
> If we are deleting it from petsc-3.4, there are a few files that can
> have more stuff deleted:
> $ git grep -l 'ALE::'
> bin/processSummary.py
Removed.
> config/PETSc/FEM.py
This will be removed when we finish moving FIAT to DMDT.
> src/dm/impls/plex/plexfem.c
This is code that needs to be rewritten.
> src/docs/doxygen/Doxyfile
Fixed
> src/snes/examples/tutorials/ex72.c
Fixed.
> We can delete the sieve-dev mailing list and reference to it.
> src/docs/website/miscellaneous/mailing-lists.html:          <td>: For
> Sieve users</td>
Satish, how do I delete this?
> Update the FAQ to recommend DMPlex.
> src/docs/website/documentation/faq.html:          use the Sieve construct
> in PETSc, this is a high
Fixed
> Remove src/docs/tex/manual/sieve.tex
   Done.
> Sieve is also referenced from src/docs/strategy.tex, which is an
> outdated personal fragment that should probably also be deleted.
Removed.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130512/0bc30087/attachment.html>
