[petsc-dev] The errors when running petsc/src/snes/examples/tutorials/ex19.c in PETSc
Lulu Liu lulu.liu at kaust.edu.sa
Thu May 9 03:09:01 CDT 2013
I replace  the file "nasm.c" in branch *next* with "nasm.c" in branch *
prbrune/snes-nasmview*, and it works now!
Thank you!
On Wed, May 8, 2013 at 11:12 PM, Peter Brune <prbrune at gmail.com> wrote:
> I've made -snes_view for NASM a bit more full featured.  Once again, I
> cannot reproduce your problem, but it needed to be fixed up anyways.
> It's in branch prbrune/snes-nasmview.  Trying it (to see if your problem
> still exists) would be appreciated.
> - Peter
> On Tue, May 7, 2013 at 2:05 PM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
>> I used next branch and got these errors. However, I pulled master and
>> test ex19.c, and got the following errors:
>>  0 SNES Function norm 5381.22
>>   1 SNES Function norm 3104.04
>>   2 SNES Function norm 777.712
>>   3 SNES Function norm 45.9649
>>   4 SNES Function norm 0.195115
>>   5 SNES Function norm 6.28208e-06
>> SNES Object: 2 MPI processes
>>   type: newtonls
>>   maximum iterations=50, maximum function evaluations=10000
>>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>   total number of linear solver iterations=47
>>   total number of function evaluations=0
>>   SNESLineSearch Object:   2 MPI processes
>>     type: bt
>>       interpolation: cubic
>>       alpha=1.000000e-04
>>     maxstep=1.000000e+08, minlambda=1.000000e-12
>>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>>     maximum iterations=40
>>   SNES Object:  (npc_)   2 MPI processes
>>     type: nasm
>>       Nonlinear Additive Schwarz: total subdomain blocks = 2
>>       Nonlinear Additive Schwarz: restriction/interpolation type - BASIC
>>       Nonlinear Additive Schwarz: subSNES iterations: 275635578 subKSP
>> iterations: -2128747920
>>       [0] number of local blocks = 1
>>       [1] number of local blocks = 1
>>       Local SNES objects:
>>       SNES Object:      (npc_sub_)       1 MPI processes
>>         type: newtonls
>>         total number of linear solver iterations=1
>>         total number of function evaluations=2
>>         SNESLineSearch Object:        (npc_sub_)         1 MPI processes
>>           type: bt
>>             alpha=1.000000e-04
>> lambda=1.000000e-08
>>         KSP Object:        (npc_sub_)         1 MPI processes
>>           type: preonly
>>           maximum iterations=10000, initial guess is zero
>>           tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>           left preconditioning
>>           using NONE norm type for convergence test
>>         PC Object:        (npc_sub_)         1 MPI processes
>>           type: lu
>>             LU: out-of-place factorization
>>             tolerance for zero pivot 2.22045e-14
>>             matrix ordering: nd
>>             factor fill ratio given 5, needed 2.95194
>>               Factored matrix follows:
>>                 Matrix Object:                 1 MPI processes
>>                   type: seqaij
>>                   rows=468, cols=468, bs=4
>>                   package used to perform factorization: petsc
>>                   total: nonzeros=25552, allocated nonzeros=25552
>>                   total number of mallocs used during MatSetValues calls
>> =0
>>                     using I-node routines: found 117 nodes, limit used is
>> 5
>>           linear system matrix = precond matrix:
>>             type: seqaij
>>             total: nonzeros=8656, allocated nonzeros=8656
>>             total number of mallocs used during MatSetValues calls =0
>>               using I-node routines: found 117 nodes, limit used is 5
>> [1]PETSC ERROR: PetscCommDuplicate() line 183 in
>> /Users/liul/soft/petsc/src/sys/objects/tagm.c
>> [1]PETSC ERROR: PetscSynchronizedFlush() line 450 in
>> /Users/liul/soft/petsc/src/sys/fileio/mprint.c
>> [1]PETSC ERROR: PetscViewerFlush_ASCII() line 135 in
>> /Users/liul/soft/petsc/src/sys/classes/viewer/impls/ascii/filev.c
>> [1]PETSC ERROR: PetscViewerFlush() line 30 in
>> /Users/liul/soft/petsc/src/sys/classes/viewer/interface/flush.c
>> [1]PETSC ERROR: SNESView_NASM() line 222 in
>> /Users/liul/soft/petsc/src/snes/impls/nasm/nasm.c
>>  [1]PETSC ERROR: SNESView() line 251 in
>> /Users/liul/soft/petsc/src/snes/interface/snes.c
>> [1]PETSC ERROR: SNESView() line 336 in
>> [1]PETSC ERROR: SNESSolve() line 3677 in
>>  [1]PETSC ERROR: main() line 157 in src/snes/examples/tutorials/ex19.c
>> application called MPI_Abort(MPI_COMM_WORLD, 872626446) - process 1
>> [cli_1]: aborting job:
>> On Tue, May 7, 2013 at 9:14 PM, Peter Brune <prbrune at gmail.com> wrote:
>>> I can't reproduce.  Have you pulled master recently?  Those line numbers
>>> don't correspond to anything, and that file hasn't changed very much in a
>>> while.
>>> - Peter
>>> On Tue, May 7, 2013 at 11:31 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
>>>> mpirun -n 2  ./ex19 -da_refine 2 -da_overlap 2 -snes_monitor_short
>>>> -snes_type aspin  -grashof 4e4 -lidvelocity 100   -snes_view
>>>>   type: newtonls
>>>>     type: bt
>>>>       alpha=1.000000e-04
>>>> lambda=1.000000e-08
>>>>     type: nasm
>>>>       Nonlinear Additive Schwarz: subSNES iterations: 114022506 subKSP
>>>> iterations: 564006000
>>>>       Local SNES objects:
>>>>         type: newtonls
>>>>         total number of function evaluations=3
>>>>           type: bt
>>>>             alpha=1.000000e-04
>>>> lambda=1.000000e-08
>>>>           type: preonly
>>>>           type: lu
>>>>             matrix ordering: nd
>>>>                   type: seqaij
>>>> calls =0
>>>> is 5
>>>>             type: seqaij
>>>> [1]PETSC ERROR: SNESView_NASM() line 240 in
>>>> [1]PETSC ERROR: SNESSolve() line 3804 in
>>>> Best wishes,
>>>> Lulu Liu
>>>> Applied Mathematics and Computational Science
>>>> King Abdullah University of Science and Technology
>>>> Tel:+966-0544701599
>>>> This message and its contents, including attachments are intended
>>>> solely for the original recipient. If you are not the intended recipient or
>>>> have received this message in error, please notify me immediately and
>>>> delete this message from your computer system. Any unauthorized use or
>>>> distribution is prohibited. Please consider the environment before printing
>>>> this email.
>> Best wishes,
>> Lulu Liu
>> Tel:+966-0544701599
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this email.
Best wishes,
Lulu Liu
Tel:+966-0544701599
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130509/d4d839c1/attachment.html>
