[petsc-dev] Lower memory DMDA
Peter Brune prbrune at gmail.com
Wed May 8 07:45:53 CDT 2013
The coordinate DM also is automatically created and has dim fields in its
vectors, making it far more heavyweight than a scalar problem.  It should
definitely be something that's lazily evaluated.
- Peter
On Wed, May 8, 2013 at 7:39 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Well, the scatter operations are collective, so making creation lazy here
> > seems fine.
> > I have no problem forcing a setup of local-to-global since I do not think
> > many people
> > use it directly.
> It gets added to any Mat or Vec that gets created.  Any code that uses
> VecSetValuesLocal() or MatSetValuesStencil() would fail without it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130508/2d22041e/attachment.html>
