[petsc-dev] The errors when running petsc/src/snes/examples/tutorials/ex19.c in PETSc
Lulu Liu lulu.liu at kaust.edu.sa
Tue May 7 14:05:25 CDT 2013
I used next branch and got these errors. However, I pulled master and test
ex19.c, and got the following errors:
 0 SNES Function norm 5381.22
  1 SNES Function norm 3104.04
  2 SNES Function norm 777.712
  3 SNES Function norm 45.9649
  4 SNES Function norm 0.195115
  5 SNES Function norm 6.28208e-06
SNES Object: 2 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=47
  total number of function evaluations=0
  SNESLineSearch Object:   2 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  SNES Object:  (npc_)   2 MPI processes
    type: nasm
      Nonlinear Additive Schwarz: total subdomain blocks = 2
      Nonlinear Additive Schwarz: restriction/interpolation type - BASIC
      Nonlinear Additive Schwarz: subSNES iterations: 275635578 subKSP
iterations: -2128747920
      [0] number of local blocks = 1
      [1] number of local blocks = 1
      Local SNES objects:
      SNES Object:      (npc_sub_)       1 MPI processes
        type: newtonls
        total number of linear solver iterations=1
        total number of function evaluations=2
        SNESLineSearch Object:        (npc_sub_)         1 MPI processes
          type: bt
            alpha=1.000000e-04
lambda=1.000000e-08
        KSP Object:        (npc_sub_)         1 MPI processes
          type: preonly
          maximum iterations=10000, initial guess is zero
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          left preconditioning
          using NONE norm type for convergence test
        PC Object:        (npc_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 2.95194
              Factored matrix follows:
                Matrix Object:                 1 MPI processes
                  type: seqaij
                  rows=468, cols=468, bs=4
                  package used to perform factorization: petsc
                  total: nonzeros=25552, allocated nonzeros=25552
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 117 nodes, limit used is 5
          linear system matrix = precond matrix:
            type: seqaij
            total: nonzeros=8656, allocated nonzeros=8656
[1]PETSC ERROR: PetscCommDuplicate() line 183 in
/Users/liul/soft/petsc/src/sys/objects/tagm.c
[1]PETSC ERROR: PetscSynchronizedFlush() line 450 in
/Users/liul/soft/petsc/src/sys/fileio/mprint.c
[1]PETSC ERROR: PetscViewerFlush_ASCII() line 135 in
/Users/liul/soft/petsc/src/sys/classes/viewer/impls/ascii/filev.c
[1]PETSC ERROR: PetscViewerFlush() line 30 in
/Users/liul/soft/petsc/src/sys/classes/viewer/interface/flush.c
[1]PETSC ERROR: SNESView_NASM() line 222 in
/Users/liul/soft/petsc/src/snes/impls/nasm/nasm.c
[1]PETSC ERROR: SNESView() line 251 in
/Users/liul/soft/petsc/src/snes/interface/snes.c
[1]PETSC ERROR: SNESView() line 336 in
[1]PETSC ERROR: SNESSolve() line 3677 in
[1]PETSC ERROR: main() line 157 in src/snes/examples/tutorials/ex19.c
application called MPI_Abort(MPI_COMM_WORLD, 872626446) - process 1
[cli_1]: aborting job:
On Tue, May 7, 2013 at 9:14 PM, Peter Brune <prbrune at gmail.com> wrote:
> I can't reproduce.  Have you pulled master recently?  Those line numbers
> don't correspond to anything, and that file hasn't changed very much in a
> while.
> - Peter
> On Tue, May 7, 2013 at 11:31 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
>> mpirun -n 2  ./ex19 -da_refine 2 -da_overlap 2 -snes_monitor_short
>> -snes_type aspin  -grashof 4e4 -lidvelocity 100   -snes_view
>>   type: newtonls
>>     type: bt
>>       alpha=1.000000e-04
>> lambda=1.000000e-08
>>     type: nasm
>>       Nonlinear Additive Schwarz: subSNES iterations: 114022506 subKSP
>> iterations: 564006000
>>       Local SNES objects:
>>         type: newtonls
>>         total number of function evaluations=3
>>           type: bt
>>             alpha=1.000000e-04
>> lambda=1.000000e-08
>>           type: preonly
>>           type: lu
>>             matrix ordering: nd
>>                   type: seqaij
>> =0
>> 5
>>             type: seqaij
>> [1]PETSC ERROR: SNESView_NASM() line 240 in
>> [1]PETSC ERROR: SNESSolve() line 3804 in
>> Best wishes,
>> Lulu Liu
>> Applied Mathematics and Computational Science
>> King Abdullah University of Science and Technology
>> Tel:+966-0544701599
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before printing
>> this email.
Best wishes,
Lulu Liu
Tel:+966-0544701599
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130507/aa4e5771/attachment.html>
