[petsc-dev] The errors when running petsc/src/snes/examples/tutorials/ex19.c in PETSc
Lulu Liu lulu.liu at kaust.edu.sa
Tue May 7 11:31:01 CDT 2013
mpirun -n 2  ./ex19 -da_refine 2 -da_overlap 2 -snes_monitor_short
-snes_type aspin  -grashof 4e4 -lidvelocity 100   -snes_view
 0 SNES Function norm 5381.22
  1 SNES Function norm 3104.04
  2 SNES Function norm 777.712
  3 SNES Function norm 45.9649
  4 SNES Function norm 0.195115
  5 SNES Function norm 6.28208e-06
SNES Object: 2 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=47
  total number of function evaluations=0
  SNESLineSearch Object:   2 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  SNES Object:  (npc_)   2 MPI processes
    type: nasm
      Nonlinear Additive Schwarz: total subdomain blocks = 2
      Nonlinear Additive Schwarz: restriction/interpolation type - BASIC
      Nonlinear Additive Schwarz: subSNES iterations: 114022506 subKSP
iterations: 564006000
      [0] number of local blocks = 1
      [1] number of local blocks = 1
      Local SNES objects:
      SNES Object:      (npc_sub_)       1 MPI processes
        type: newtonls
        total number of linear solver iterations=1
        total number of function evaluations=3
        SNESLineSearch Object:        (npc_sub_)         1 MPI processes
          type: bt
            alpha=1.000000e-04
lambda=1.000000e-08
        KSP Object:        (npc_sub_)         1 MPI processes
          type: preonly
          maximum iterations=10000, initial guess is zero
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          left preconditioning
          using NONE norm type for convergence test
        PC Object:        (npc_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 2.95194
              Factored matrix follows:
                Matrix Object:                 1 MPI processes
                  type: seqaij
                  rows=468, cols=468, bs=4
                  package used to perform factorization: petsc
                  total: nonzeros=25552, allocated nonzeros=25552
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 117 nodes, limit used is 5
          linear system matrix = precond matrix:
            type: seqaij
            total: nonzeros=8656, allocated nonzeros=8656
[1]PETSC ERROR: PetscCommDuplicate() line 183 in
/Users/liul/soft/petsc/src/sys/objects/tagm.c
[1]PETSC ERROR: PetscSynchronizedFlush() line 450 in
/Users/liul/soft/petsc/src/sys/fileio/mprint.c
[1]PETSC ERROR: PetscViewerFlush_ASCII() line 135 in
/Users/liul/soft/petsc/src/sys/classes/viewer/impls/ascii/filev.c
[1]PETSC ERROR: PetscViewerFlush() line 30 in
/Users/liul/soft/petsc/src/sys/classes/viewer/interface/flush.c
[1]PETSC ERROR: SNESView_NASM() line 240 in
/Users/liul/soft/petsc/src/snes/impls/nasm/nasm.c
[1]PETSC ERROR: SNESView() line 251 in
/Users/liul/soft/petsc/src/snes/interface/snes.c
[1]PETSC ERROR: SNESView() line 336 in
[1]PETSC ERROR: SNESSolve() line 3804 in
[1]PETSC ERROR: main() line 157 in src/snes/examples/tutorials/ex19.c
application called MPI_Abort(MPI_COMM_WORLD, 872626446) - process 1
[cli_1]: aborting job:
Best wishes,
Lulu Liu
Applied Mathematics and Computational Science
King Abdullah University of Science and Technology
Tel:+966-0544701599
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130507/3ef5bb25/attachment.html>
