[petsc-dev] Preconditioners for GPU
Andrea Lani andrea.lani at gmail.com
Mon May 6 12:40:13 CDT 2013
Ok, I ll try jacobi. I am also testing MHD cases by the way (interaction of Solar wind and earth Magnetosphere, both steady and unsteady) :-)
Thx
Andrea
On May 6, 2013, at 7:17 PM, "Nystrom, William D" <wdn at lanl.gov> wrote:
> Andrea,
> Have you tried jacobi preconditioning with gpus.  I've found it to work pretty
> well, surprisingly, and it does work in parallel with mpi.  It is also worth seeing
> if you can use the ell or hyb matrix formats.  I have seen a reduction in compute
> time using ell/hyb matrix formats of typically 2x up to as much as 5x when the
> iteration counts get large.  You should also try both the cusp and cusparse
> mat_type.  I've tried the above on extended mhd problems.  YMMV.
> Having said that, I am looking forward to trying better preconditioners for gpus
> as they become available.  But it would be interesting to see if jacobi preconditioning
> on the gpu solves your problem faster than your best preconditioning option on
> the cpu.  Also, all my problems have been SPD.
> Dave
> Dave Nystrom
> LANL HPC-5
> Phone: 505-667-7913
> Email: wdn at lanl.gov
> Smail: Mail Stop B272
>        Group HPC-5
>        Los Alamos National Laboratory
>        Los Alamos, NM 87545
> From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Andrea Lani [andrea.lani at gmail.com]
> Sent: Monday, May 06, 2013 10:52 AM
> To: Paul Mullowney
> Cc: petsc-dev at mcs.anl.gov
> Subject: Re: [petsc-dev] Preconditioners for GPU
> Thanks Paul! this only work for sequential cases, right? in this case, what performance benefit should I expect compared to a fully CPU-based version, if any? is anything available also for parallel runs?
> Andrea
> On Mon, May 6, 2013 at 5:48 PM, Paul Mullowney <paulm at txcorp.com> wrote:
> Hi Andrea,
> The matrix type, aijcusparse has an ILU(n) (and ICC(n) for symmetric problems) preconditioner. The factorization is done on the CPU. The solves are done on the GPU via the cusparse library.
> In the configure, do --download-txpetscgpu=yes
> I would also look at:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSEQAIJCUSPARSE.html
> for information on the aijcusparse class.
> -Paul
>> On Sun, May 5, 2013 at 4:26 PM, Andrea Lani <andrea.lani at gmail.com> wrote:
>> Thanks, Matt! Let me re-iterate on the question... are there other available preconditioners already ported to GPU, which are not based on AMG (which is typically not suitable for my convection-dominated CFD problems) and apart from BICGSTABCUSP?
>> I believe that the txpetscgpu package has triangular solves for the GPU.
>> BiCGStab is a Krylov method.
>>    Matt
>> Andrea
>> On May 5, 2013, at 9:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sun, May 5, 2013 at 2:48 PM, Andrea Lani <andrea.lani at gmail.com> wrote:
>>> Dear Developers,
>>> Could you please tell me the list of preconditioners for non-symmetric systems fully ported to multi-GPU and available in the current development version?
>>> In my opinion, there are no truly multi-GPU preconditioners anywhere. We can imagine them, like AMG with Chebychev smoothers, but
>>> I have not really seen any of them reliably work. The CUSP SA-AMG is the closest one in this category, and Steve Dalton is working on
>>> it this summer at ANL.
>>>   Matt
>>> Thanks in advance
>>> Andrea
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>> -- Norbert Wiener
> Dr. Andrea Lani
> Senior Research Engineer, PhD
> Aeronautics & Aerospace dept., CFD group
> Von Karman Institute for Fluid Dynamics
> Chausse de Waterloo 72,
> B-1640, Rhode-Saint-Genese,  Belgium
> fax  : +32-2-3599600
> work : +32-2-3599769
> lani at vki.ac.be
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130506/86669c53/attachment.html>
