[petsc-dev] [PATCH] config: test functions and headers only once
Wed May 1 06:16:55 CDT 2013
On Tue, Apr 30, 2013 at 11:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matt, would you like to go about this differently, maybe by preventing
> duplicates from appearing in the first place?
I was originally worried about state (like LIBS) since this is manipulated
in autoconf.
If we agree that all these checks should be stateless, we could do
something with
this toplevel check, like everyone registers the function/headers they are
looking
for in __init__() and we check up front.
   Matt
> Jed Brown <jedbrown at mcs.anl.gov> writes:
> > Many functions and headers are mentioned in both BuildSystem and PETSc,
> > thus being tested more than once.  Removing this redundancy speeds up my
> > configure from 125 seconds to 110 seconds.
> > I have not de-duplicated libraries.py yet because it passes in more
> > structured arguments.  It only runs a few tests multiple times:
> > [(['socket', 'nsl'], 'socket'), (['fpe'], 'handle_sigfpes'), (['socket',
> 'nsl'], 'socket'), (['fpe'], 'handle_sigfpes')]
> > These are actually all defined in one place, but it is visited multiple
> > times:
> /home/jed/petsc/mpich-basic/conf/reconfigure-mpich-basic.py(12)<module>()
> > -> configure.petsc_configure(configure_options)
> >   /home/jed/petsc/config/configure.py(290)petsc_configure()
> > -> framework =
> config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:],
> loadArgDB = 0)
> >   /home/jed/petsc/config/BuildSystem/config/framework.py(110)__init__()
> > -> self.createChildren()
> /home/jed/petsc/config/BuildSystem/config/framework.py(319)createChildren()
> > -> self.getChild(moduleName)
> >   /home/jed/petsc/config/BuildSystem/config/framework.py(304)getChild()
> > -> config.setupDependencies(self)
> >> /home/jed/petsc/config/PETSc/Configure.py(105)setupDependencies()
> > -> self.libraries.libraries.extend(libraries1)
> >   /home/jed/petsc/config/configure.py(293)petsc_configure()
> > -> framework.configure(out = sys.stdout)
> >   /home/jed/petsc/config/BuildSystem/config/framework.py(929)configure()
> > -> self.updateDependencies()
> /home/jed/petsc/config/BuildSystem/config/framework.py(385)updateDependencies()
> > -> child.setupDependencies(self)
> Matt, can we avoid visiting here more than once?
> >  config/BuildSystem/config/functions.py | 4 ++++
> >  config/BuildSystem/config/headers.py   | 4 ++++
> >  2 files changed, 8 insertions(+)
> > diff --git a/config/BuildSystem/config/functions.py
> b/config/BuildSystem/config/functions.py
> > index 30da45e..7b700cb 100644
> > --- a/config/BuildSystem/config/functions.py
> > +++ b/config/BuildSystem/config/functions.py
> > @@ -197,5 +197,9 @@ choke me
> >        self.executeTest(self.checkSignalHandlerType)
> >      self.executeTest(self.checkFreeReturnType)
> >      self.executeTest(self.checkVariableArgumentLists)
> > +    try:
> > +      self.functions = list(set(self.functions))
> > +    except:
> > +      pass
> I put in this guard because I thought set() was python-2.5.  Evidently
> it is in python-2.4, so we're safe, provided the list contains only
> hashable objects.  It should, right?
> >      map(lambda function: self.executeTest(self.check, function),
> self.functions)
> >      return
> > diff --git a/config/BuildSystem/config/headers.py
> b/config/BuildSystem/config/headers.py
> > index e180eaa..f3da45c 100644
> > --- a/config/BuildSystem/config/headers.py
> > +++ b/config/BuildSystem/config/headers.py
> > @@ -230,6 +230,10 @@ class Configure(config.base.Configure):
> >      self.executeTest(self.checkSysWait)
> >      self.executeTest(self.checkTime)
> >      self.executeTest(self.checkMath)
> > +    try:
> > +      self.headers = list(set(self.headers))
> > +    except:
> > +      pass
> >      map(lambda header: self.executeTest(self.check, header),
> self.headers)
> >      self.executeTest(self.checkRecursiveMacros)
> >      return
> > 1.8.2.1
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130501/09c63d62/attachment.html>
