[petsc-dev] CMake-assisted CUDA builds ready
Jose E. Roman jroman at dsic.upv.es
Tue Mar 26 11:03:45 CDT 2013
El 26/03/2013, a las 16:19, Karl Rupp escribió:
> Hi Jose,
> alright, the problem should be fixed in 'next' now. The problem was in CMake not consistently interpreting escaped double quotes.
> Best regards,
> Karli
Not yet solved:
/usr/local/cuda/bin/nvcc /home/jroman/soft/petsc/src/mat/impls/aij/mpi/mpicusp/mpiaijAssemble.cu " -O -arch=sm_13 " "--compiler-options ,-fPIC,-Wall,-Wwrite-strings,-Wno-strict-aliasing,-Wno-unknown-pragmas,-O" -m64 -D__INSDIR__= -Dpetsc_EXPORTS -Xcompiler ,\"-fPIC\" -DNVCC -M -o /home/jroman/soft/petsc/arch-linux-gnu-c-opt-cuda/CMakeFiles/petsc_generated_mpiaijAssemble.cu.o.NVCC-depend -I/usr/local/cuda/include -I/home/jroman/soft/petsc/include -I/home/jroman/soft/petsc/arch-linux-gnu-c-opt-cuda/include -I/usr/local/cuda/include -I/home/jroman/soft/petsc/arch-linux-gnu-c-opt-cuda/include/txpetscgpu/include -I/home/jroman/soft/cusplibrary -I/home/jroman/soft/cusplibrary/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
nvcc fatal   : Unknown option '-compiler-options ,-fPIC,-Wall,-Wwrite-strings,-Wno-strict-aliasing,-Wno-unknown-pragmas,-O'
CMake Error at CMakeFiles/petsc_generated_mpiaijAssemble.cu.o.cmake:173 (message):
  Error generating
  /home/jroman/soft/petsc/arch-linux-gnu-c-opt-cuda/./petsc_generated_mpiaijAssemble.cu.o
