[petsc-dev] PETSc/Cygwin and Intel Visual Studio
Thu Mar 21 09:58:36 CDT 2013
On Thu, 21 Mar 2013, Chen Shapira wrote:
> Hi Everyone,
> While building PETSc in Cygwin, I've noticed the following warning :
> "You are using an Intel supplied intrinsic header file with a
> third-party compiler."
Must be intel compiler issue [when mixing icl with ifort]
> It seems that the configure and 'make' were completed well,
> but when I'm testing the petsc tutorials/examples, I sometimes get
> strange errors/warnings such as :
> In ex2 and ex3 : "Error : Window Not Successfuly Created"
> In ex7 , ex10 and others : "Warning: win32fe: Library Path Not Found:
> /home/petsc-dev/PROGRA~2IntelCOMPOS~3binia32"
I'm not sure what the error means. Does the compile go through fine?
Is this with PETSc makefiles - with the same compiler env setup [as
[per the installation instructions?]
You can send us the complete compile log
Satish
> Any ideas on what to do ?
> Thanks
> Chen
