[petsc-dev] Dealing with off-processor aij-matrices not having preallocation information
Karl Rupp rupp at mcs.anl.gov
Thu Mar 21 09:08:16 CDT 2013
 >     Yes, I want to preserve the behavior Barry described in 2), i.e.
>     only error if the user specified an allocation pattern explicitly.
>     I'm only questioning the way it is currently implemented:
>     If the number of nonzeros is specified as PETSC_DECIDE to
>     MatSeqAIJSetPreallocation___SeqAIJ(),
>     it does not set MAT_NEW_NONZERO_ALLOCATION___ERR. If the number of
>     nonzeros is larger than zero, it does. So far, so good.
> If nnz is nonnegative, yes.
right, it's actually nz >= 0.
>     MatMPIAIJSetPreallocation___MPIAIJ(), however, first checks for the
>     number of nonzeros. If it is PETSC_DECIDE, it sets defaults and then
>     calls MatSeqAIJSetPreallocation___SeqAIJ() with the defaults.
>     Because MatSeqAIJSetPreallocation___SeqAIJ() no longer sees
>     PETSC_DECIDE, it sets MAT_NEW_NONZERO_ALLOCATION___ERR, which is
>     then reset right after in MatMPIAIJSetPreallocation___MPIAIJ(). The
>     CUSP-implementation does not reset the flag and thus leads to
>     errors, even though the implementation of the CUSP-Preallocation
>     routine looks perfectly fine. I rather want to fix the hack in
>     MatMPIAIJSetPreallocation___MPIAIJ() than to propagate it to the GPU
>     implementations as well.
> I thought perhaps you were going to leave it to the _SeqAIJ parts to
> store the nonew state. If the _MPIAIJ part resolves PETSC_DECIDE
> independently from the _SeqAIJ part, then they have to *always* coincide
> exactly, otherwise we'll have very confusing bugs. You can likely
> forward PETSC_DECIDE down to the _SeqAIJ parts, then query a->nonew and
> b->nonew to set the mpiaij->nonew flag. (I'm not sure it's consistent
> now, but we want it to be consistent.)
There is no mpiaij->nonew flag in Mat_MPIAIJ, this is all handled in the
two diagonal/off-processor matrices of type Mat_SeqAIJ. I don't want to
change this ;-)
I just want to resolve the way way a->nonew and b->nonew is set, so that
it does not require a hack in MatMPIAIJSetPreallocation_MPIAIJ().
A closer look showed three options:
  a) just forward PETSC_DECIDE to MatSeqAIJSetPreallocation_SeqAIJ(),
don't modify the nonew-flags from _MPIAIJ(). This almost fixes the
problem, the only drawback is that the number of nonzeros on the
off-processor blocks is then also 5 instead of 2 when using PETSC_DECIDE.
  b) Allow to pass default values to MatSeqAIJSetPreallocation_SeqAIJ().
The cause of the issue is that MatSeqAIJSetPreallocation_SeqAIJ() does
two things: It interprets PETSC_DECIDE and it does the preallocation. If
we split these two tasks into two functions, i.e.
  - MatSeqAIJSetPreallocation_SeqAIJ() for interpreting PETSC_DECIDE and
dealing with nonew, then calling
  - MatSeqAIJSetPreallocation_SeqAIJAlloc() for the actual preallocation
we can directly call MatSeqAIJSetPreallocation_SeqAIJAlloc() from the
_MPIAIJ() part and cleanly set MAT_NEW_NONZERO_ALLOCATION_ERR for the
on- and off-processor matrices.
  c) Improve the existing hack by querying the state of a->nonew and
b->nonew before calling MatSeqAIJSetPreallocation_SeqAIJ() and after
that reset a user-defined state if necessary.
I'll create a pull request for b), as it is consistent with the current
behavior and appears to be the cleanest solution to this.
Best regards,
Karli
