[petsc-dev] Unable to find zlib library
Chen Shapira chen2600 at gmail.com
Thu Mar 21 06:35:35 CDT 2013
Thanks Satish, I've successfuly configured it now
C.
On Wed, Mar 20, 2013 at 5:51 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Make sure you have gcc/g++ from cygwin installed for sowing.
> Satish
> On Wed, 20 Mar 2013, Chen Shapira wrote:
>> Thanks Satish,
>> I've tried :
>> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
>> --with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
>> (x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
>> --with-petsc-arch=arch-mswin-c-debug
>> --CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
>> --ignore-cygwin-link --with-valgrind=0 --with-c2html=0
>> --download-sowing=1 --with-hdf5=1
>> --with-hdf5-include=/cygdrive/c/libraries/hdf5/include
>> --with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,/cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
>> --LIBS=/cygdrive/c/libraries/hdf5/libs/zlib.lib
>> and also with : --LIBS='/cygdrive/c/libraries/hdf5/libs/zlib.lib'
>> and I got a different error :
>> Error running make; make install on Sowing (install manually): Could
>> not execute "cd /home/petsc-dev/externalpackages/sowing-1.1.16d &&
>> make &&  make install && make clean":
>> (cd src/sys && make )
>> make[1]: Entering directory
>> `/home/petsc-dev/externalpackages/sowing-1.1.16d/src/sys'
>> cl.exe  -I../../include -I../../include    -c arch.c
>> arch.c
>> arch.c(22) : fatal error C1083: Cannot open include file:
>> 'sys/utsname.h': No such file or directory
>> ../../Makerules:39: recipe for target `arch.o' failed
>> make[1]: Leaving directory
>> Makefile:18: recipe for target `libs' failed
>> Thanks again
>> Chen
>> On Tue, Mar 19, 2013 at 4:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > zlib detection code is a bit wired. Try using the additional option:
>> > Satish
>> > On Tue, 19 Mar 2013, Chen Shapira wrote:
>> >> Hi Again,
>> >> While configuring PETSc in Cygwin,
>> >> I recieve the following error :
>> >> "Compression library [libz.a or equivalent] not found"
>> >> The thing is, I already have the file : zlib.lib included in the
>> >> configuration of petsc .
>> >> My configure command is :
>> >> Thank you again..
>> >> Chen
