[petsc-dev] I question the existence of PetscErrorCode (*createlocaltoglobalmapping)(DM); PetscErrorCode (*createlocaltoglobalmappingblock)(DM);
Wed Mar 20 09:30:49 CDT 2013
done
On Wed, Mar 20, 2013 at 9:18 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 20, 2013, at 9:14 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Wed, Mar 20, 2013 at 9:02 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    This is wrong and needs fixing, having one name for the public
> interface and a different name in the function table. You need to change
> the name in the function table to get() and
> DMCreateLocalToGlobalMapping_Composite() and friends to use the name DMGet…
> > That would imply that each DM* implementation would need to manage
> caching, which is a bit of boilerplate, but perhaps okay in the interest of
> consistency. Or do we start/reinforce a convention that some implementation
> Get methods are called at most once because the outer part manages caching?
>    No. Just change the name but leave everything else identical to the way
> it is now. There is nothing wrong with the way it is implemented, just the
> inconsistent naming.
>    Barry
> >    Having this inconsistent naming already wasted my time, and your time
> responding to the email and everyone else's time in having to delete the
> email. I'd fix it but git workflow is too hard so you need to fix it.
> Consistency reduces complexity.
> > I don't mind making the change, but here's the process to get a new
> branch into 'next':
> > $ git checkout -b name/dmgetlocaltoglobalmapping master
> > change source, test, and commit
> > $ git checkout next
> > $ git merge name/dmgetlocaltoglobalmapping
> > $ test
> > $ git push origin next name/dmgetlocaltoglobalmapping
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130320/146eada4/attachment.html>
