[petsc-dev] Unable to find zlib library
Chen Shapira chen2600 at gmail.com
Wed Mar 20 05:34:01 CDT 2013
Thanks Satish,
I've tried :
./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
--with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
(x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
--with-petsc-arch=arch-mswin-c-debug
--CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
--ignore-cygwin-link --with-valgrind=0 --with-c2html=0
--download-sowing=1 --with-hdf5=1
--with-hdf5-include=/cygdrive/c/libraries/hdf5/include
--with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,/cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
--LIBS=/cygdrive/c/libraries/hdf5/libs/zlib.lib
and also with : --LIBS='/cygdrive/c/libraries/hdf5/libs/zlib.lib'
and I got a different error :
Error running make; make install on Sowing (install manually): Could
not execute "cd /home/petsc-dev/externalpackages/sowing-1.1.16d &&
make &&  make install && make clean":
(cd src/sys && make )
make[1]: Entering directory
`/home/petsc-dev/externalpackages/sowing-1.1.16d/src/sys'
cl.exe  -I../../include -I../../include    -c arch.c
arch.c
arch.c(22) : fatal error C1083: Cannot open include file:
'sys/utsname.h': No such file or directory
../../Makerules:39: recipe for target `arch.o' failed
make[1]: Leaving directory
Makefile:18: recipe for target `libs' failed
Thanks again
Chen
On Tue, Mar 19, 2013 at 4:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> zlib detection code is a bit wired. Try using the additional option:
> Satish
> On Tue, 19 Mar 2013, Chen Shapira wrote:
>> Hi Again,
>> While configuring PETSc in Cygwin,
>> I recieve the following error :
>> "Compression library [libz.a or equivalent] not found"
>> The thing is, I already have the file : zlib.lib included in the
>> configuration of petsc .
>> My configure command is :
>> Thank you again..
>> Chen
