[petsc-dev] Why does configure ignore compiler output?
Richard Tran Mills rtm at eecs.utk.edu
Tue Mar 19 22:07:46 CDT 2013
I seem to recall that compilers on Cray systems were (and still are)
huge offenders in the spewing meaningless output department.  I like the
"blacklist" suggestion.
--Richard
On 3/18/13 9:27 PM, Jed Brown wrote:
> On Mon, Mar 18, 2013 at 8:24 PM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>     You can always turn that switch off for your test. What we were
>     finding is that some crappy compilers
>     were killing everything by putting in meaningless output for every
>     compile. We don't rip it out because
>     maybe those compilers die and we flip the switch in the new release.
> What about a blacklist containing output that we do interpret as failure?
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130319/614734a6/attachment.html>
