[petsc-dev] PTScotch 6
Tue Mar 19 11:54:19 CDT 2013
On Tue, Mar 19, 2013 at 11:20 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> I don't understand this. you mean 'master' at the end? So you mean:
> - create a 'patch' branch off 'maint' and apply this patch.
yes
> - merge this 'patch' branch to 'maint'
> - merge this 'patch' branch to 'next'
Merge 'patch' into 'next' first so that it can be tested before going to
more stable branches.
> Sorry - I meant to say 'it has merges from 3.2' - so I'm not sure how
> eqivalent it is to previous 3.3-petsc+3.3-bs - and if we should generate
> patch updates for 3.3 from this or not.
Yes, it's basically the same, except for 'patch' branches being able to go
spend time in 'next' before 'patch' appears in 'maint', as above. We'll
make maintenance releases from 'maint'.
Also, I would prefer to name maintenance releases 3.4.X instead of 3.4pX so
that version comparison macros can be used. Sometimes PETSc fixes a bug in
a maintenance release and other applications do not have a nice way to test
for that. Subminor release numbers conventionally mean "source- and
binary-compatible", so I don't see any value in  3.4pX numbering.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130319/85805b78/attachment.html>
