[petsc-dev] bad code that needs fixing
Paul Mullowney paulm at txcorp.com
Mon Mar 18 16:10:14 CDT 2013
Thanks Jose. One last patch ... hopefully.
-Paul
> Also, rank should be PetscMPIInt as well as size.
> Jose
> El 18/03/2013, a las 20:54, Paul Mullowney escribió:
>> Should have caught that.
>> -Paul
>>>     device must be cast to int before being passed to cudaSetDevice().
>>>    cudaSetDevice(device);
>>> On Mar 17, 2013, at 3:36 PM, Paul Mullowney<paulm at txcorp.com>   wrote:
>>>> Here's a patch following the instructions on the wiki for small patches.
>>>> -Paul
>>>>>      int size;
>>>>>      ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
>>>>>      if (size>1) {
>>>>>        int devCount, device, rank;
>>>>>        ierr   = cudaGetDeviceCount(&devCount);CHKERRQ(ierr);
>>>>>        ierr   = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
>>>>>        device = rank % devCount;
>>>>>        ierr   = cudaSetDevice(device);CHKERRQ(ierr);
>>>>>      } else {
>>>>>        int device;
>>>>>        /* the code below works for serial GPU simulations */
>>>>>        ierr = PetscOptionsGetInt(NULL,"-cuda_set_device",&device,&flg1);CHKERRQ(ierr);
>>>>>        if (flg1) {
>>>>> size int should be PETScMPIInt and device int cannot be an int if it is passed to PetscOptionsGetInt which requires a PetscInt.
>>>> <0001-cuda-device-selection.patch>
>> <0002-cuda-device-selection.patch>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130318/a299aac7/attachment.ksh>
