[petsc-dev] bad code that needs fixing
Mon Mar 18 07:27:39 CDT 2013
   device must be cast to int before being passed to cudaSetDevice().
  cudaSetDevice(device);
On Mar 17, 2013, at 3:36 PM, Paul Mullowney <paulm at txcorp.com> wrote:
> Here's a patch following the instructions on the wiki for small patches.
> -Paul
>>     int size;
>>     ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
>>     if (size>1) {
>>       int devCount, device, rank;
>>       ierr   = cudaGetDeviceCount(&devCount);CHKERRQ(ierr);
>>       ierr   = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
>>       device = rank % devCount;
>>       ierr   = cudaSetDevice(device);CHKERRQ(ierr);
>>     } else {
>>       int device;
>>       /* the code below works for serial GPU simulations */
>>       ierr = PetscOptionsGetInt(NULL,"-cuda_set_device",&device,&flg1);CHKERRQ(ierr);
>>       if (flg1) {
>> size int should be PETScMPIInt and device int cannot be an int if it is passed to PetscOptionsGetInt which requires a PetscInt.
> <0001-cuda-device-selection.patch>
