[petsc-dev] [petsc-users] Eigenvalue solver method in Petsc
Sun Mar 17 12:50:17 CDT 2013
   We should support the Msys interface, what stands in the way of it.
   Barry
On Mar 17, 2013, at 12:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Mar 17, 2013 at 11:59 AM, Sonya Blade <sonyablade2010 at hotmail.com> wrote:
> >SLEPc is the eigensolver package build on PETSc.
> >http://www.grycap.upv.es/slepc/
> >It is easy to install and use after installing PETSc.
> So the Petsc can not solve it on its own w/o Slepc?
> PETSc is not an eigensolver package. You can write an eigensolver using PETSc or you can use SLEPc.
> >Cygwin is required to build PETSc, but not to use it.
> How about the MSys interface, which I've already installed.
> Not currently, as far as I know.
