[petsc-dev] bad code that needs fixing
Sat Mar 16 20:41:22 CDT 2013
    int size;
    ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
    if (size>1) {
      int devCount, device, rank;
      ierr   = cudaGetDeviceCount(&devCount);CHKERRQ(ierr);
      ierr   = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
      device = rank % devCount;
      ierr   = cudaSetDevice(device);CHKERRQ(ierr);
    } else {
      int device;
      /* the code below works for serial GPU simulations */
      ierr = PetscOptionsGetInt(NULL,"-cuda_set_device", &device, &flg1);CHKERRQ(ierr);
      if (flg1) {
size int should be PETScMPIInt and device int cannot be an int if it is passed to PetscOptionsGetInt which requires a PetscInt.
